Coolant Leak at coolant temp sensor
Old Oct 4, 2023 | 09:04 AM
andrewdgalyon's Avatar
andrewdgalyon
Default Coolant Leak at coolant temp sensor
I had the thermostat housing crack on my 05 4.0 V6 replaced it and reused the old coolant temperature sensor and now have a slight leak at the sensor but only when cold when it warms up leak goes away I’m assuming a failing O-ring has anyone ever experienced this problem?
Old Oct 4, 2023 | 10:29 AM
JimC's Avatar
Super Moderator
Your assumption of a failed O ring is likely correct.
Although many people have had multiple thermostat housings fail in a short time with the plastic one. But since it seems to be at the sensor itself that leads to the O ring as most likely.
Topless Stang
Apr 8, 2015 07:17 PM
leitzpower
Aug 25, 2007 06:32 PM
HBCHINO
Mar 17, 2007 05:52 PM
tommy_t
Jan 29, 2006 08:56 PM
blurbro
Jul 27, 2004 11:44 AM
