Shifting issue
Old Dec 1, 2024 | 08:45 PM
DKnight's Avatar
DKnight
Default Shifting issue
So, I've a 2011 GT/CS, recently I've been having issue to shift into first and second gear at stop light, I have to really force it into gear. It didn't happen all the time, but when it does it's almost impossible to put it into gear. The car currently has 145k. Do you guys think it's the transmission or just clutch?
Old Dec 1, 2024 | 10:01 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
I would start by checking the fluid in the master reservoir and checking for leaks from the master and slave
Old Dec 2, 2024 | 03:06 AM
DKnight's Avatar
DKnight
I couldn't find the dip stick to check the fluid level.
Old Dec 2, 2024 | 04:31 AM
Dino Dino Bambino's Avatar
Dino Dino Bambino
The clutch & brake hydraulic systems share the same reservoir that's placed in front of the brake booster. There's no dipstick. Just remove the cap and inspect the fluid level.
If the fluid is old & darkened, you should have it replaced with fresh DOT 4 brake fluid. That alone could make all the difference.
Old Dec 2, 2024 | 04:50 AM
DKnight's Avatar
DKnight
So even I have no issue at all with my brake but it might affect the gear shift?
Old Dec 2, 2024 | 03:35 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
it will have problems going into first and second if the pressure plate is not releasing the clutch from the flywheel. For whatever reason that is.
Old Dec 3, 2024 | 12:49 AM
Dino Dino Bambino
Yes. Mind you if you have fresh fluid in the reservoir, the brake pedal will also feel a bit firmer. The fluid is hygroscopic (absorbs water) and loses its viscosity over time. Therefore it should ideally be replaced every three years, or even more frequently if you live in a very humid climate.
Old Dec 3, 2024 | 08:31 AM
DKnight's Avatar
DKnight
Thank you, I will check that out when I get home, according the Ford app it says brake was services back in 22 but again when I tried to call that place they said that VIN had never been there...
Old Dec 3, 2024 | 08:32 AM
DKnight's Avatar
DKnight
Oh ****, I just realized the name is from need for speed lol
FoxbodySnakes97
May 10, 2018 06:34 AM
fossum24
5.0L V8 Technical Discussions
Mar 29, 2012 07:58 PM
abecker
Jun 1, 2009 03:28 PM
V6yellowStang
Oct 21, 2006 03:53 AM
V8Cody
14
Mar 23, 2006 12:52 PM
