Transmission?
Hey guys I'm new here lol and have a problem with my 1986 5.0 gt 302 manual trans .So I don't know if I need a new transmission but I will go to put it into gear (EX: at a stop light) and it won't go, like there is no gear there . It doesn't happen everytime but more than a few times if I'm just cruising around town . Please help me !!!
What if you try to shift it into some other gear, 2nd, 3rd, etc? What happens then? Difficult to understand your description. Are you saying the shift lever will not MOVE, or that it does move, but the car does not move when you release the clutch pedal? imp
the shift Lever will go into all gears , but every once in a while I will be in N and it can move around a little(like normal when you are in N) but then I go to put it into a gear( I have had it happen to every gear except reverse ) and it will not shift into that gear even with the clutch fully engaged, I have not had a problem with the car moving, when it is in a gear
Evenexchange
Mar 7, 2010 08:36 AM
PurpleMustang1996
Jan 13, 2010 02:40 PM
Waldron93
May 28, 2009 09:42 PM
mAnYsTyLeS
Aug 29, 2008 12:38 AM
Hoops_5_1
Mar 26, 2006 06:13 PM
