TECH: replacing the stock throttle body
Old Mar 2, 2007 | 01:08 PM
  #31
m_stavros's Avatar
m_stavros
Default RE: TECH: replacing the stock throttle body
ORIGINAL: shaners90lxhatch
What do you want to know? There are four TP wires and two TACM (Throttle Actuator Control Motor) circuits....... the actual voltage is different than this anticipated value - you end up with failsafe mode.
What a post! Full of technical serius information! THANK YOU
I am trying to fit a larger throttle body tomy duratec HE engine.
Is a throttle by wire system but slight different. The TPS and the TACM are in the same potition.
Old Mar 2, 2007 | 01:15 PM
  #32
m_stavros's Avatar
m_stavros
Is a six pinadaptor in one port so i was wondering if i could splitmine 6 cablesinthe two ports of your throttle body
Old Mar 2, 2007 | 02:23 PM
  #33
shaners90lxhatch's Avatar
shaners90lxhatch
What kind of vehicle to do you have? Duratec with ETB....hmmm.. And you want to use a Mustang throttle body? I don't know about compatability. I can tell you which wires are what and where you would have to put them to make the throttle body from a stang work, but I can't tell you if it will work or not.
Old Mar 2, 2007 | 02:29 PM
  #34
m_stavros's Avatar
m_stavros
Can you send me a block diagram of the circuit? Or can you tell me which wires are what andwhereto connect them
Thank you
Old Mar 2, 2007 | 02:47 PM
  #35
shaners90lxhatch
Sure thing. I need to know what vehicle you have first.
Old Mar 2, 2007 | 03:03 PM
  #36
mustangman2424's Avatar
mustangman2424
I ♥ Acer
Not trying to be mean or anything, but unless you plan to do major engine modifications there is no reason why you should get a new TB. The stock one is very good, and if you manage to uprgrade it with no problems (which is highly unlikely) is the trouble really worth 2-3 hp? Buying a new muffler will get those results and it make the car sound better at the same time. So basicaly if you are looking to get the highest hp NA as possible than a new TB is porobably a good idea, but if you aren't then there is really no reason to replace the stock TB.
Old Mar 2, 2007 | 03:11 PM
  #37
shaners90lxhatch
I agree. But judging by the pinout of the throttle body connector, it seems this guy is trying to put a mustang TB on something other than a stang. Hell, I am likely wayyyyy confused.[8D]
Old Mar 2, 2007 | 03:19 PM
  #38
m_stavros's Avatar
m_stavros
Ford focus 2.0 duratec HE (Eurospec).
Old Mar 2, 2007 | 03:27 PM
  #39
shaners90lxhatch
Wont work dude. We don't even make a Focus with electronic throttle (in the US). I do not have materials for European vehicles.
Old Mar 2, 2007 | 03:32 PM
  #40
m_stavros's Avatar
m_stavros
ok, thank you anyway.
I'm buying a used oneto test it. Its a "shoot in the dark" i know, butim going to make it work.
Thank you, and sorry for the off topic posts.
