eibach prokit help
hey guys, i need some pictures of the 05 mustang gt on some eibach pro kit lowering springs, and if you could get those with a chin spoiler that would be great, but i need some pictures just so i can have an idea of what it'll look like on an 05. thanks
The car looks great! I just bought the eibach prokit. I only wanted to lower the car about 3/4" in the rear to get it even. Can you give me any details on what to expect when I change the springs out? How is the ride,did you change the shocks, what did you do for the rear end alignment[8D]
rear alignment??? i had a front end alignment done and they also suggested that i get camber adjusters. as for the ride, it made it quite a bit stiffer but with my bfg's and the springs, it handles alot better than factory. plus, i think it looks alot better than stock...the 05's sit way too high from the factory IMO
I just found the Roush springs for the rear. These springs only lower the car 1". Has anyone used these or got any feed back. I bought the Pro kit but I still have mixed feelings about installing them, if I need to spend the big bucks for shocks/struts also I would think the right way to go would be the full suspension kit. I am not trying to set up a competion car I would just like to level her out.
Just have done rears (Eibach ProKit) so far. See pic. Ford has rear end up so high this has solved that and I may not touch the front unless the rear settles more. Every person but one I've see so far had to switch in adj panhard bar to bring rear end back in alignment (side to side) Mine was out 1/2"-5/8" ; BMR adj ph bar is quality, solves that
ssue.
BTW, pic is with full tank of gas.
[IMG]local://upfiles/24316/94E647FE20ED438CBB2A17DBC65D09BE.jpg[/IMG]
ssue.
. I would try and find you one, but I am too lazy to do it as well.
