Cold start problem
Old Jan 12, 2006 | 09:56 AM
swieduwi's Avatar
swieduwi
Default Cold start problem
every morning for the past week I get in to start my car, but when I turn the key the engine turns over but the car does not start, I let go of the key and I hear a bunch clicking for about 3-5 seconds. I turn the ingnition off then try to restart the car ind it starts fine. Has anyone heard of such a problem or any ideas what it could be.
I am afraid to take it to the dealer untill I put the stock tune back, remove the CAI, UD pullys, CMDP and Throttle body, in fear that they will blame my problems or damage on the mods.
Old Jan 12, 2006 | 10:53 AM
Hambone's Avatar
Hambone
Default RE: Cold start problem
Not to be silly but---when you start the car, do you "pause" after turning the key part way, and THEN crank it? You need to--it gives it time for a shot of fuel to be pumped in....if you listen closely, you can hear it.
If you ARE starting it like this, then maybe you have a real problem and it's NOT squirting the fuel in...
Just a thought!
As for the clicking---not sure about that. I do hear some type of "solenoid" that sounds more like something spinning, and then it eventually stops. I noticed this from flashing the car with the Xcal2...it just became obvious from all of the key off/key on steps.
Old Jan 12, 2006 | 04:54 PM
swieduwi's Avatar
swieduwi
I am turning the key all the way, as for the clicking it sounds like several solenoids clicking. very loud I will capture a recording in the am, it only happens in the morning.
Old Jan 12, 2006 | 07:09 PM
SPARTAN VI's Avatar
SPARTAN VI
I had the same problem my first week, just personal error. The ignition didn't fire up as quickly as I thought, or sometimes I hear it and it didn't, so I'd let go, start again to get a nasty grinding noise.
Haven't done it since.
Old Jan 12, 2006 | 10:06 PM
chrisc's Avatar
chrisc
the same thing happens to my girlfriend's civic when it is too cold and she parks outside overnight
her brother (who is a car junky too) said that it might be that condensation is freezing in the injectors
Old Jan 13, 2006 | 09:23 AM
swieduwi's Avatar
swieduwi
ORIGINAL: SPARTAN VI
No I have had this car for 6 months, that this just started, It turns over just will not start like it not getting fuel or no spark. It's about 40 deg so freezing condensation is not the issue. I had a Dyno tune about three weeks ago and a Throttle body installed.
Old Jan 13, 2006 | 09:53 AM
JJ_Stang's Avatar
JJ_Stang
A bunch of people are having problems with the TB try removing that and see if it gets better.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
drfister
May 3, 2018 10:38 PM
MXBT187
Aug 20, 2015 02:36 AM
HIS S-197
Aug 10, 2015 05:47 PM
