anybody relocated the battery?
somebody has to have done it. if so which kit(if any) did you use and did you run both cables from the trunk? also how did you hook into the factory cables? i don't want to cut the factory cables up so i'm going to try to find a junction block that will accept the battery terminal end and then have a provision for the extension cable to the trunk. if no one has done it yet then i'll post info and pics when i figure it out.
logan409
09-26-2015 07:43 PM
