Informational Documents
Old Jun 29, 2006 | 06:18 PM
  #31
06GT4RAD's Avatar
06GT4RAD
Default RE: Everything you ever wanted to know about OCTANE
ORIGINAL: Professor Wizard
EVERYTHING you ever wanted to know about OCTANE...
http://www.prime-mover.org/Engines/G...es/octane.html
Good Info.
Richard
Old Jul 17, 2006 | 11:58 PM
  #32
Stroken97's Avatar
Stroken97
Default RE: Informational Documents
any chance you can post the trunk release link again?
Old Jul 18, 2006 | 12:00 PM
  #33
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Trunk Release...
http://www.cherod.com/mustang/HowTo/TrunkRelease.htm
Old Jul 18, 2006 | 12:12 PM
  #34
Professor Wizard
MF Moderator
Ford TSB Listings...
http://www.alldata.com/tsb/Ford/index-issue.html
Old Jul 20, 2006 | 02:41 PM
  #35
BlackSpirit's Avatar
BlackSpirit
would there happen to be an easier diagram for installing new springs, the only diagram I saw showed the struts and I am sure there has to be an easier way then removing the entire front esembly. Thanks
By the way awesome information! thanks!
Old Jul 20, 2006 | 06:55 PM
  #36
06GT4RAD's Avatar
06GT4RAD
The front struts are very easy to remove. Simply unbolt the lower two mounting bolts the sway bar end link and then the 4 bolts up top and the strut will practically fall out. Be sure and support the brake rotor hub Assembly as it will try to fall out of place and you may damage the lower ball joint if you let it .
Richard
Old Jul 21, 2006 | 03:16 PM
  #37
BlackSpirit
Appreciate it much!
Old Jul 21, 2006 | 06:53 PM
  #38
Professor Wizard
MF Moderator
Please don't be offended... I am going to leave these posts here for a little longer..
then I am going to delete them - - - cleanup so that only the listings of documentation is on here without the chat.
Old Jul 26, 2006 | 01:36 PM
  #39
GT Premi's Avatar
GT Premi
Calculations, calculations, and more calculations!
Old Jul 28, 2006 | 03:05 PM
  #40
kcary's Avatar
kcary
Oh dear god I think I just found my bathroom reading material for the next year! Looks like its time to go back to school in a way lol.
