Trunk grounding
Old Feb 25, 2006 | 10:59 PM
skilz4u2nv's Avatar
skilz4u2nv
Default Trunk grounding
I'm now putting the finishing touches on my sub box... I'm also putting an amp in the trunk that needs to be grounded... Before I go and start tearing and lifting through the carpet in the trunk can someone tell me where the closest grounding point (i.e. some screw i can take advantage of) in there is? Thanks
Old Feb 25, 2006 | 11:39 PM
cstigger04's Avatar
cstigger04
Default RE: Trunk grounding
Yes under your back seat there is a bracket held down but (2) #45 torx bit screws perfect grounding spot.....thats what I did.
Old Feb 25, 2006 | 11:41 PM
skilz4u2nv's Avatar
skilz4u2nv
Under the back seat? Anything actually in the trunk. My wire isnt too long
Old Feb 25, 2006 | 11:45 PM
cstigger04's Avatar
cstigger04
My ground wire is 18". As far as actually in the trunk, I didn't look because I wanted a stealth install. I discovered this when I pulled my whole interior out to run the power wire for the remote turn on and the Sat radio antenna. plus power wire install 4ga.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
