Question Installing Vinyl Stripes
Old Jun 1, 2010 | 07:22 AM
majik755's Avatar
majik755
Default Question Installing Vinyl Stripes
About to install a vinyle center stripe on my 2010. Intend to eventually paint it if the style works for me. Most of it will be no problem, but my car came with Satellite radio and the rear deck antenna. Does anyone know how to remove it so it can be reinstalled after the striping? Is there a bolt from the bottom in the trunk or is it 3M taped. Probably my weekend project, so just would like to know what I'm in for when I try to get it off. Thanks for any input.
Old Jun 1, 2010 | 09:55 AM
Xcelsius's Avatar
Xcelsius
Im having a stripe put on this month. I will take a look at the trunk later today if no one answers before I get off work. Its probably easy to remove from the underside.
Old Jun 1, 2010 | 08:59 PM
fyerfyter's Avatar
fyerfyter
its just a simple lock /nut and bolt piece threw your trunk ....I wish i could take it off all together without a big whole to fill in...what stripe are you going with...
Old Jun 2, 2010 | 07:16 AM
majik755's Avatar
majik755
fyerfyter
Thanks, that sounds great, I was dreading removing 3M tape and reinstalling that way. I was hoping it was a nut and bolt. I noticed a rubber gasket at the bottom so I thought that might be the case. The stripe is similar to yours, my Stang is Sterling Grey Metallic, will have a silver stripe, wide stripe in center with one inch stripes on each side.
Old Jun 2, 2010 | 10:26 AM
JWButler14's Avatar
JWButler14
post pics of your strips asap majik
Old Jun 2, 2010 | 10:40 AM
majik755's Avatar
majik755
Will do, hopefully this weekend barring any problems.
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
mustangv6305
Aug 29, 2015 01:37 PM
movielover40
Aug 27, 2015 10:13 PM
Mr. D
Big Worm Graphix
Aug 18, 2015 01:51 AM
