TPMS???
Old Sep 23, 2011 | 11:10 PM
treborwd22's Avatar
treborwd22
Default TPMS???
Is it better to just buy a new set of TPMS or can you reuse the ones off the stock tires?
Old Sep 24, 2011 | 09:06 AM
157dB's Avatar
157dB
Cut & Paste Expert
What ever floats your boat and checking account.
Selling old rims to a 2001 mustang owner or saving
them for winter tires?
Old Sep 24, 2011 | 11:08 AM
wanakanabe's Avatar
wanakanabe
I have the band type sensors on my car and the shop just transferred them to the new wheels.I think the 2010 Mustangs use valve stem type sensors,seems those would be even easier to transfer.They all are pretty fragile so i would make sure to take it to a reputable shop.I also think they have to be re calibrated and my shop did that as well.
The other option is to just ditch them altogether,i have heard many people just taking some 2 1/2" pvc pipe,attached on air valve,throw them in,seal it up,pressurize it and throw it in the trunk.
Old Sep 24, 2011 | 12:06 PM
157dB's Avatar
157dB
Cut & Paste Expert
missed a step there....
seal it up
wait for the glue to cure (24 hours)
then fill it up with air
Old Sep 24, 2011 | 03:03 PM
treborwd22's Avatar
treborwd22
OK.... Thanks for your answers. I took my car to my local Tire Shop and they just used my OEM TPMS and everything works fine.
Old Sep 25, 2011 | 01:34 AM
stealth_GT's Avatar
stealth_GT
TPMS both suck and help at the same time.. they seem to only register a fault when it's 25 psi or lower, by then it's too late and your driving on the rim. I have had cars with the TPMS light SOLID, which means that it's been on for an extended period of time lol
Most normal people have no friggin' idea what it means, even though it's obviously an exclamation mark as in " fvck you! Look at me!", yet no one cares rofl
It's cool when the bands are opposite of the valve stem (where it should be), but you sometimes get that total douche that will install it where ever the hell he feels like it and when you bust the bead, you break the sensor..DOH!
$95-150 down the shietter!.. for you! lulz
Old Oct 8, 2011 | 11:10 AM
157dB's Avatar
157dB
Cut & Paste Expert
Yep, thats why there are procedures that need to be followed
if one is going to call themselves a trained tire technician...
The days of Gomer Pyle with no technical training fixing your vehicle
correctly are long gone.
Old Oct 15, 2011 | 08:21 PM
STANGmole's Avatar
STANGmole
About 10 years ago I had a '95 Cobra. I took it in to the shop to have Eibach springs installed and the shop topped off the air in the tires. What I didn't realize was that the rubber oring in the valve stem cap was sideways and when they screwed it on it depressed the pin and was slowly leaking air. After driving for about 2 hours on the way to Seattle my car started to pull to one side and I pulled over. The tire was TOAST. It was smoking and completely shredded. Back then it was a big tire and difficult to get (Corvette was the only other car with one that size and it was a $270 tire...expensive now let alone back then). I was forced to watch Titanic and stay in a crap hotel while they express shipped the tire to the shop.
Moral of the story...if I had TPMS in that car it never would have happened. 25psi is not driving on the rim!
spectreman
Mar 31, 2016 09:26 PM
blueshawk
Mar 22, 2008 11:22 AM
blueshawk
Jan 14, 2008 12:37 PM
cartel
Wheels & Tires
Oct 11, 2007 06:54 PM
sycd
Wheels & Tires
Apr 21, 2007 09:52 PM
