Metra Dash Kit Install
Old Jun 5, 2012 | 09:29 AM
bones302's Avatar
bones302
lots of people have installed the Metra kits without issue. If you contact them, I'm sure they'll make good.
Old Jun 5, 2012 | 09:35 AM
raceman94's Avatar
raceman94
Okay, so I called "tech support" and they think it could be a firmware issue. They've said they've never heard of an issue like this. They said to find some numbers on the back and give them a call back. The problem is that the old unit only says "Assembled by Hedi." Either way, Crutchfield has sent me another one. It should arrive today. I'll install it and give you folks an update after that.
Old Jun 5, 2012 | 03:30 PM
raceman94's Avatar
raceman94
Okay! So I replaced the dash kit and it powered on and didn't automatically go into defrost. That's an improvement. However, the climate controls still wouldn't work. Oh dear. I had tried several things and the last thing I did was disconnect and reconnect the battery. That seemed to do the trick and it works like it should now. I hope this lasts.
Old Jun 5, 2012 | 03:32 PM
GTR21's Avatar
GTR21
I've seen these and Scoche ones.. but I've heard of some issues with both
Old Jun 5, 2012 | 03:38 PM
raceman94's Avatar
raceman94
I read about the firmware issues with the Scoche one.
Old Jun 5, 2012 | 04:24 PM
GTR21's Avatar
GTR21
Yah, some kinda battery drain thing. Apparently been solved with that firmware, but with such new products and applications, I guess you have to expect glitches
Old Jun 5, 2012 | 04:44 PM
bones302's Avatar
bones302
I suggest you find this Hedi guy and beat the $%& out of him!
I have the Scosche kit and it had a firmware issue where it was draining the battery. they sent me a new one with the firmware upgrade and it's been working fine for the last 5 months. I'm sure you'll be ok from here on.
Old Jun 5, 2012 | 06:36 PM
raceman94's Avatar
raceman94
LOL. But it gets better: The second unit says the same thing. Apparently both units were assembled by Hedi.
Old Jun 5, 2012 | 07:34 PM
Antonio323's Avatar
Antonio323
Did you call Metra's tech support or Crutchfield? Glad to see it's working out for you so far.
Old Jun 5, 2012 | 07:42 PM
raceman94's Avatar
raceman94
Yes. Called Crutchfield first and they suggested I call Metra. I did that and seeing that Metra didn't really have a clue since "they've never heard of anything like this before" Crutchfield just sent me a new one. If if screws up again, heads will roll.
