Is drive shaft need?
I have 2011 3.7L I want to change my limited slip differential maybe my gear ratio too. But I am not sure if I need the aluminum drive shaft? As long as don't exceed 125 MPH I believe. Any advice will help.
The speed limiter is set at 114 MPH. This is supposedly because the OEM driveshaft tends to fail above that speed. If you intend to exceed this speed (closed course of course), then get an aluminum driveshaft designed for those speeds.
Hopefully this gives you a better perspective!
Shane
Thanks Shane and Everybody else I had purchased the aluminum DS from American mucsle installed it my self. Saving money now to put it on a Dyno test to see all the money I invested into my mods bare fruits for a total HP at the fly and wheel.
Changing that drive shaft is a great big PLUS++++
I hope you noticed the weight of your original DS against the new Aluminum one. The new one is much lighter and with less rotating mass is like getting added horsepower and torque. A very good mid.
Ronnie
Ronnie
09-08-2015 11:50 AM
