3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Throttle Body Boring
Old 06-15-2014, 09:04 PM
SSG Steggy
SSG Steggy's Avatar
Default Throttle Body Boring
After looking around for a while, I have noticed a lot of peeps running the BBK Throttle Body for the increase in size and volume of air flow. I can't really justify the cost of the BBK, however, I do understand the science behind it. Does anyone have any experience with MAXBORE? For $99, They will take a stock TB and bore it out to max specs, 72-73mm for our vehicles. Seems to have a good amount of positive reviews from customers. Just wondering if anyone has any input?
Thanks.
SSG Steggy is offline
Old 06-16-2014, 09:20 AM
AMAlexLazarus
Former Sponsor
AMAlexLazarus's Avatar
Thanks.
OP-
That's a good question and while I don't have any experience with Maxbore I can personally attest to how much stronger our 3.7l felt after we had installed the BBK Throttle Body and Tune. I have a pretty solid list of Bolt-On's installed on my '08 Bullitt and as aggravating as it is to say the V6 just walks all over it on the streets. For lack of a better term the 3.7l is pretty corked up and bordering asmatic. It highly benefits from a little more air getting stuffed into the motor to create some HP.
Let me know if you're to have any questions and I'm here to help!
-Alex
AMAlexLazarus is offline
Old 06-17-2014, 06:51 PM
hogasswild
hogasswild's Avatar
My wife was bored with the BBK TB too.
hogasswild is offline
Old 06-17-2014, 08:15 PM
Nuke
Nuke's Avatar
My wife gets turned on every time I start my Stang so i bore HER...
Nuke is offline
Old 07-10-2014, 02:50 PM
zacharoni16
zacharoni16's Avatar
Not sure if its the increased "SUCKING" and WHOOSHING from the CAI, but the bigger BBK throttlebody seemed to liven up the V6 especially after 3k RPM for me.
zacharoni16 is offline
Old 07-10-2014, 03:06 PM
SSG Steggy
SSG Steggy's Avatar
Thanks for the input zacharoni.
Old 08-05-2014, 08:45 PM
xenocide
xenocide's Avatar
I didn't notice a change when I swapped to the BBK TB. I installed it because after ~55k miles my tb shorted out. How is this not a part of the power-train? Anyway dealer wanted 600 or 700 dollars to replace it on top of the 100 dollar diagnostic fee. They said it was so expensive because "we have to reprogram the throttle body" bulllll sh!7. Its a plug and play part. So yeah, that is how I ended up with one.
xenocide is offline
Old 08-06-2014, 07:55 AM
SSG Steggy
SSG Steggy's Avatar
Xenocide - I've heard and seen in other posts that without a tune, you will not notice a difference when changed. Do you have a programmer/tune?
Old 08-16-2014, 01:13 PM
IvanRad
IvanRad's Avatar
my ported and polished throttle body was night and day difference.
IvanRad is offline
Old 08-16-2014, 02:01 PM
aaquib1992
aaquib1992's Avatar
Same here with my stock TB ported and polished, although mine is 4.0L so your experience may vary. I had a bit more down low power that registered well on the butt dyno.
I think mine was ported/polished at the intake openings to about ~73mm with a reduction in the size of the butterfly valve disc. but no bore. I had my tune updated for it as well.
aaquib1992 is offline
patchshaffer
Tuner Central
10-05-2015 02:24 PM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Throttle Body Boring
