3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Won't start nothing happens
Old Jun 27, 2018 | 05:28 PM
mlud00's Avatar
mlud00
Default Won't start nothing happens
My 2012 V6 intermittently won't start. Not the battery or battery connections. I turn the key and lights come on buzzing noise I think is fuel injectors priming, and then nothing. Sometimes it takes 5-10 tries. Sometimes it just starts after a second or two. I read where it may be a bad starter motor, which I replaced myself. It worked for a few weeks consistently and now doing it again. I also read it may be the starter relay but I have to research what it looks like and where it is. As you can see I am resisting taking it to the dealer, I don't want to get taken and some things I like to try myself. If relay is cheap enough I may try it myself or else I am finally willing to go to the dealer. Any comments or insight? I saw a youtube video with a 2012 V6 that does exactly what mine does , that was where i saw the explanation of starter relay.
Old Jun 28, 2018 | 10:45 AM
mlud00's Avatar
mlud00
Just in case anyone is interested or has a similar problem. I believe it is a faulty relay in the fuse box in engine compartment. I actually switched the relay next to it, the heater/ventilation fan relay, which is the same part #. The car starts and the fan doesn't now, so I believe it was the relay. I am picking on up today so hopefully this is the issue.
Old Jul 1, 2018 | 01:08 PM
mlud00's Avatar
mlud00
Put a new relay in and so far this has solved the problem. Two days and multiple starts, I hope this is the end of it. I guess no one else has had this issue?
Knightwolf61
Aug 27, 2016 01:15 PM
jshaffer30
Apr 7, 2015 11:45 AM
usc49erfan
Sep 19, 2009 09:24 PM
bertt
Apr 18, 2009 07:07 PM
v8cobra99
Jan 8, 2007 12:42 PM
