3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Programmer
Old Mar 16, 2020 | 10:07 AM
Donna Reno-Lauland's Avatar
Donna Reno-Lauland
Default Programmer
I have a 2014 V-6 that won't go over 115. I'm guessing there is a govener on it?? Would a programmer fix this and what do you recommend?
Old Mar 16, 2020 | 12:36 PM
Siber Express's Avatar
Siber Express
Yes a programmer will fix it but you need to make sure of a couple thing.
If you have 17 inch wheels you need to make sure your tires are rated for any speed you plan to go and the V6 center splined drive shaft needs to be replaced with an aftermarket end Splined.
Old Mar 16, 2020 | 12:52 PM
Donna Reno-Lauland
I understand about the tires, but the speedometer has 160 on it...shouldn't it be able to go faster without those mods?
Old Mar 16, 2020 | 05:27 PM
Siber Express
The Driveshaft is the weak point, it comes apart at about 135MPH. Ford knows this since they have have been reading about it for years.They also know the V6 programming will not let the car go that fast, so when comes apart it is the owners fault. The GT is electronically limited to 145 I do believe so even it will not do the 160 on the Speedo either.
BTW when I bought my 1972 Ranchero GT it would do 110 MPH, still 10 miles per hour short of the 120 it showed. Just because it says it can go that fast doesn't ever mean it can.
Old Mar 16, 2020 | 06:05 PM
Siber Express
Here is the Driveshaft I have in my Car and I do have a tuner from them with their programming so my car has gone over 115 but still have not seen a straightaway long enough for the 160.
My Car and the loose nut behind the wheel doing what I do best
Old Mar 17, 2020 | 07:12 AM
Donna Reno-Lauland
Default Thank you
Thank you so much for the information!!!!
Old Mar 17, 2020 | 08:13 PM
Siber Express
What, No Pics of the Car
Old Mar 18, 2020 | 06:40 AM
Donna Reno-Lauland
Old Mar 18, 2020 | 11:14 AM
Siber Express
Looks good, you have 18's so from the factory the tires were good for 144mph, but the driveshaft wasn't.
Stango36
Aug 17, 2009 08:18 AM
4.0 Stang
Dec 29, 2006 01:28 PM
Jerseyfury2
Dec 28, 2006 04:19 AM
GaryFenza89
Aug 22, 2006 11:26 AM
Stangsational
Jul 15, 2004 06:49 PM
