3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
engine code P0017
Old Apr 30, 2021 | 11:18 AM
B-2's Avatar
B-2
Question engine code P0017
My first Mustang that is newer than the 70's so I'm starting to learn the newer engines. I have a engine code of P0017 on my 2014 V-6 with 51K miles on it. I've looked online but can't find the location of the camshaft position sensor. I'm not sure if that's the first thing I need to start with or not. I know it needs new plugs now that this has started. Because it seems to be building up a lot of carbon in the throttle body. It looks like someone has put a V8 exhaust system welded behind the cats. Would it need a new tune for the swap if this is the case? Thanks for any help I'm going to need it to learn all these new electronic systems.
Old May 2, 2021 | 06:34 AM
David Young's Avatar
David Young
If this picture works. It's on the driver side near the back of the engine.
Old May 2, 2021 | 06:39 AM
David Young
By the way, P0017 is for a crankshaft 'and or' camshaft position code
Old May 2, 2021 | 10:58 AM
B-2's Avatar
B-2
Thanks for that info it's going to be a big learning curve from working on my old stuff I remember when I first put A electronic Ignition system on my 30 model-A lol
Thanks again
Old May 3, 2021 | 05:20 AM
David Young
Thanks again
I'm 2 years older than you . I've done things around the house and to my cars by watching youtube videos. Youtube has saved my butt many times. Now before I start to do something, I'll see if I can find a video before I even start
Old May 3, 2021 | 07:06 AM
B-2's Avatar
B-2
I do the same thing but so far I haven't found one that shows a video for a 2014 Mustang replacing a valve Positioning sensor so I'm just not sure we're they are on the head
Old May 24, 2021 | 06:01 PM
B-2's Avatar
B-2
Thanks for the help everyone I finally got it figured out it was the variable valve timing oil control valve solenoid. Got it replaced and it runs way better. The PO must have put cheap gas and just babied it because it had a lot of carbon every were. I'M using seafoam in the oil & gas to clean it out. I've used 2 tanks of gas with seafoam so far so good. My mileage is getting better every time I drive it and no more engine codes I'm going to change the oil & filter at 3K miles and put another can of seafoam in the oil and go from there. Thanks again B-2
mikeoffy
Sep 20, 2012 05:57 PM
dziabo
May 21, 2007 12:34 AM
slimshorti1589
May 20, 2007 12:07 AM
Newbreedgt05
Apr 14, 2006 02:53 AM
ripper
Dec 28, 2005 11:04 PM
