3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Random Startup Problem
Old Aug 24, 2022 | 09:46 PM
RoadtripMustang's Avatar
RoadtripMustang
Default Random Startup Problem
Hi!
My car started cranking for longer than normal, so I thought the issue was the battery. I changed the battery and the problem persisted. Since the car already had 98.000 miles, I took it to the dealer and had them change the spark plugs and clean the upper and lower intake. The problem still persists! So basically, the car sometimes takes longer to start than normal and it does it at random, but sometimes the car starts right away. I thought that the problem manifested after driving it during lunch time and then when it came to leaving work it did it, but this morning it did it again and it was worse, the car almost didn't start. Should I have the dealer perform a fuel system service or have them diagnose the car? The issue right now is that all the dealers near me tell me that they are short-staffed and I'll have to leave the car for at least 4 weeks for them to look at it. Any ideas on how I can diagnose the issue? When I turn the key to start, the starter kicks in like normal, but the car takes longer to start. I have no codes. The only things I notice are a loud ac compressor quick and a bit of vibration when the ac is running. Could it be dirty crank sensors? Bad fuel pump? Bad starter?
Old Sep 25, 2023 | 01:34 PM
Mike3.7's Avatar
Mike3.7
Did you ever find out the issue?
Old Sep 25, 2023 | 02:45 PM
JimC's Avatar
Super Moderator
I don't think you will get an answer from him:
  • Last Activity: 09-14-2022 04:01 PM
Your best bet is start your own thread in the 3.7section.
jskigator
Sep 22, 2017 10:52 AM
RemoGaggi
Oct 24, 2011 01:43 PM
stangc83
Dec 16, 2006 11:52 PM
tightdogal
May 15, 2006 04:07 PM
Champ561
May 12, 2006 08:25 PM
