351 Mustang
MAF meter selection
Old Mar 16, 2007 | 03:47 AM
roblarss's Avatar
roblarss
Default MAF meter selection
I am in the midst of buying the parts for my 351 swap and was wondering what size MAF I require. Im trying to keep the costs as low as possible but If I require something to make it run better I'll get it.
I think the sn95 has a 70mm stock (correct me if Im wrong)
Im either going 351w or 393 (depends on condition of crank, ect. when I tear it apart next week) with afr 185, approx 9.5-10.0:1 cr, intake not decided yet (suggest one if you can). No turbo/charger or nitrous.
Will I need to get a new MAF and TB? Not getting them may solve a few tuning issues Im going to have (need computer tuned before I run it, but want to run engine a bit before I take to dyno tune).
I have been jumping all around on this build trying to decide the matching of parts, but that is all ending this week when I go out and get the parts finally ordered.
I really need some help from the experts here and even some of the other guys too.
Thanks
Old Mar 16, 2007 | 05:02 PM
vristang's Avatar
vristang
Default RE: MAF meter selection
Rob
what ecu are you using?
You may not require a custom tune, but that will depend on the cam, etc.
I would try and get a 70mm MAF, or larger.
24-36lb injectors, depending on the heads and cam... I'm not sure how to figure that though.
jason
Old Mar 16, 2007 | 05:19 PM
roblarss's Avatar
roblarss
Thanks
I was looking at 36# injectors. I have the afr 185 heads ordered. Just have to wait for 3-4 months they told me to get them in stock.
Im using the stock sn95 ecu and was told that a 70mm (supposidly stock ) is large enough for that application. I am probably going to get a custom cam or talk to someone at a cam store for a good off the shelf cam.
Just trying to not overbuy parts that arent really necessary.
Thanks
jwog666
Dec 27, 2021 08:09 PM
2007CalSpec
Dec 13, 2020 11:42 AM
carid
Jul 8, 2016 09:55 AM
Dathan
Oct 5, 2015 05:52 AM
uedlose
Sep 10, 2015 01:37 PM
