351 Mustang
roller blocks
Old Aug 21, 2007 | 01:53 PM
  #21
WhiteWindsor's Avatar
WhiteWindsor
Default RE: roller blocks
ORIGINAL: USMCrebel
ok, i can live with 350-400. heres the setup i plan on tring to run when i get my 351 stang
351 stroked to 408 (forged)
holley 600-650
afr 205cc
i dont know much about cams, so i was planning on using a .500+ lift and 580 duration
high compression pistons
h beam rods
a dual planeweinand intake
any suggestions?
You will need more carb, i run a 750 on my 357 but i have big cam. You will def. want something in 550+ lift for cam. I would wait and build engine then see what size carb you need, it will depend alot on how many RPM you will be turning as well as everything else. A dual plane will help you with low end, but if this car will be seeing high rpm shifts i would go with single plane. I use a victor jr. I have forged I-beams and Diamond Racing Pistons, those pistons are pricey, Full sells stroker kits, ask him for his reccomadations.
Old Aug 21, 2007 | 01:54 PM
  #22
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
i love manuals, but it seems that a built c4 would be best forme. which would you reccommend?
Old Aug 21, 2007 | 09:17 PM
  #23
MadMan@TheWheel's Avatar
MadMan@TheWheel
A built C-4. They are affordable, easy to find and have tons of combinations.
Old Aug 21, 2007 | 11:23 PM
  #24
USMCrebel's Avatar
USMCrebel
whast the power limit on the c-4's
Old Aug 22, 2007 | 10:09 AM
  #25
USMCrebel's Avatar
USMCrebel
i got away from my origionla questions, what is the advantages and disadvantages of the roller blocks?
Old Aug 22, 2007 | 12:18 PM
  #26
FullAuto's Avatar
FullAuto
Advantage - You can run the proper cam with standard roller lifters. No need to buy a poor RBC cam or expensive lifters.
Disadvantage - Considered the weakest of the production blocks. Cost more for the core.
Old Aug 22, 2007 | 12:32 PM
  #27
USMCrebel's Avatar
USMCrebel
so if i used a 69-70 block and did a roller conversion i would be good right?
Old Aug 22, 2007 | 02:04 PM
  #28
FullAuto's Avatar
FullAuto
Correct. Buy Comp link bar lifters and you're good.
Old Aug 22, 2007 | 02:25 PM
  #29
USMCrebel's Avatar
USMCrebel
ok. thats what i like to hear.
thanks.
Old Aug 22, 2007 | 02:28 PM
  #30
w8less's Avatar
w8less
and you will have a stonger block
*coughs* i am selling a 351w roller shortblock*
