351 Mustang
tunnel ram?
Old Aug 30, 2007 | 09:59 PM
86stanglx's Avatar
86stanglx
Default tunnel ram?
is there any performance gain or advantage from running a tunnel ram on a 351 or 302 stroker? or pretty much just look kick a**?
Old Aug 31, 2007 | 03:35 PM
MadMan@TheWheel's Avatar
MadMan@TheWheel
Default RE: tunnel ram?
There is an advantage if you have the motor to utilize it. The issue is that most "low rise" intakes work well enough to provide what most engines need. A prot matched Victor Sr. intake will make amazing numbers without having to punch a hole in your hood
Old Aug 31, 2007 | 03:50 PM
86stanglx's Avatar
86stanglx
what kind of set would utalize one?
Old Aug 31, 2007 | 04:17 PM
MadMan@TheWheel
They are normally used when massive amounts of fuel is used, the lare runners lend the manifold to a huge cooling effect on the incoming fuel/air. Can you decide to bolt one up and run it? Yes, right cam and head set-up and you can run it. But like I said, do you really need one for you application is basically up to you. Unless you are doing it for looks you will generally see them on large horsepower cars that need lots of fuel right now, then get sent back to the pits for rest
ccdguy
Sep 19, 2015 05:20 PM
New Era Performance
Apr 20, 2004 10:17 PM
USAMuscle
Sep 15, 2003 05:12 PM
tchamber
Aug 27, 2003 07:38 PM
swap
May 31, 2003 12:02 PM
