351 Mustang
performance question?
Old Oct 7, 2007 | 10:06 PM
fastrnu70's Avatar
fastrnu70
Default performance question?
Any advise would be appreciated. I have been having alittle problem with pinging. I have played with the timing and added octane boost. I am running 10.5 to 10.8 compression with a comp 280h cam. I have talked to several people running this compression on pump gas without pinging, but I still get it alittle on WOT. I am thinking that if I upgrade to all MSD it might help. Also, would the plug gap be an issue or bigger wires. I am at .35 with autolite 45's and standard wires. Thanks for the help.
Old Oct 8, 2007 | 12:21 AM
w8less's Avatar
w8less
Default RE: performance question?
what octane do you put in there?
Old Oct 8, 2007 | 11:01 PM
fastrnu70's Avatar
fastrnu70
91 plus a booster
Old Oct 9, 2007 | 02:58 AM
MadMan@TheWheel's Avatar
MadMan@TheWheel
Carbed or F/I?
The reason I ask is I have ran 10:5:1 plus cars carbed, and they can lean out cylinders if you are not careful. I have also had the distributor nut losen and had the distributor move on me also. Another thing to realize is that the "ping" yoou hear may not be detonation, high compression cars make a distinct noise if you are running long tube especially.
How about some more information? Timing etc..
Tivo304
Aug 28, 2023 12:19 PM
M3hunter
Sep 5, 2015 03:42 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
cbird1177711
Sep 2, 2015 08:51 PM
