351 Mustang
stock 351 or mild 408 with STOCK C4 tranny?
Old 11-28-2007, 01:33 PM
5.8l coupe
5.8l coupe's Avatar
Default stock 351 or mild 408 with STOCK C4 tranny?
would i be able to run a completely stock c4 tranny behind a mild 408w? meaning just an everyday 10:1 comp, stock otb 170cc tw aluminum heads, rpm air gap intake, carb'd, flat tappet and probably changing to a hyd roller cam, maybe on the bottle from time to time for giggles and that's it? would a c4 live or no?
or even behind a completely stock 351 with tw heads or maybe even a set of junkyard 351 heads, stock rods, pistons, crank, cam? and maybe some spray, but i forgot how much the stock pistons can take, does anyone rememer off the top of their head right now? thanks
5.8l coupe is offline
Old 11-29-2007, 03:51 PM
psuhillbilly150
psuhillbilly150's Avatar
Default RE: stock 351 or mild 408 with STOCK C4 tranny?
there are guys out there that make fully built C4s handle 1000+ horses so the stock one must have had something going for it. Just a question if your going to go 408 and put heads on it why not get 200+ ports so you have room to grow and I am sure 11 to 1 comp pistons are no more expensive then 10 to 1. with the intake and cam and stock bottom endyour good to 6200 Rs no problem why not take advantage
psuhillbilly150 is offline
Old 11-29-2007, 06:43 PM
5.8l coupe
5.8l coupe's Avatar
the reason for not having a head with over 200cc, yet, is because of funds, i just have to work with what i have for the time being. and as far as the bottom end question, it's already put together and i wanted to be sure i stayed within pumpgas-ability. although i know 11:1 can be just as safe and streetable, i just wanted a bit more security that i could find the gas i needed anywhere i go, especially since i like driving around until the needle meets the needle stop lol
Old 12-01-2007, 04:11 PM
uedlose
uedlose's Avatar
it could last a long time if your not standing on it and running the crap out of it all the time
uedlose is offline
Old 12-01-2007, 05:18 PM
rust_stang
I ♥ Acer
rust_stang's Avatar
those head would be choking the engine, stroker like to breathe! save and put on some 205 or 210's
rust_stang is offline
Tyoung68
08-25-2015 04:31 AM
FD725
08-11-2015 03:43 AM
MelloYello
05-25-2004 02:51 AM
TheGmKiller331
02-26-2004 12:38 AM
Strike
09-25-2003 12:45 AM
Quick Reply: stock 351 or mild 408 with STOCK C4 tranny?
