Stall Converter ?
Old May 24, 2004 | 07:57 PM
MelloYello's Avatar
MelloYello
Default Stall Converter ?
Ok Im running stock motor, stock cam, intake etc.... Have mild bolt on's.....
My last tranny had a Transgo Shift Kit and a 3000 stall
Stall was too high, and I am now rebuilding another one..... My brake stall is about 3200 should I go with a 2000-2300 stall or 2200-2600? I don't know the flash stall.....
But the specs are -
AODE w/ shift kit
shifts at 5.5
street/strip
4:10 w/ 8.8
3900 lbs
Also what brands are good, I'd like first hand info please thanks... my old one was by tci
Old May 24, 2004 | 07:59 PM
MelloYello's Avatar
MelloYello
Default RE: Stall Converter ?
Also anyone here tried Transgo and B & M both... Any differences in shifting? Ive never gone with B & M ...........I've heard YES! and NO! about that brand......
Old May 25, 2004 | 02:15 AM
roundman's Avatar
roundman
My best advice is call several tranny companies and tell them exactly what mods you have made and then ask them for a recommendation on a converter. A good company will ask you a lot of questions to get the correct information to make a decision, so if they don't spend a lot of time asking questions, then don't go with their recommendation. Besides TCI and B&M, you can check with Art Carr Performance Transmissions, Lentech Automatics, Turbo-Action, Hughes, Performance Automatic, Dynamic Racing Transmission, ATI, and there are others but these are the biggest ones. My guess would be something around 2,500 stall, but that is just a guess.
Old May 25, 2004 | 02:27 AM
skylark494's Avatar
skylark494
Your stock cam probably played the biggest roll in your converter. The 3000 stall was most likely robbing you of low end torque because it was a tad out of your cams operating range. Give the trans companies as much info as possible and they will help you select the proper converter. I'd say about 2000 stall.
Old May 25, 2004 | 02:51 AM
MelloYello's Avatar
MelloYello
Thats what I figured.... thought Id ask anyways
Yeah I knew that stall before was robbin me, thats why Im rebuilding a new one... I figured it made it wear faster also...
Im thinkin 2000-2400
I found one I think at EdgeRacing.... Have to cal lthe guy tommorrow, they will custom make me one Yay!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
