351C into Foxbody
RE: 351C into Foxbody
The only thing that I was concerned with is the stock K-member heavier. I hear you can save 20lbs easy with a tubular. But then again, im trying to go the cheepest and safest way i can.
Milodon and Moroso makes pans for this swap, I bought mine from summit. The pickup needed a little tweaking to get the clearance to the pan right. I am going with an AJE crosmember which will give me a little more hood clearance and shed some weight. You will have to have a pretty serious t-5 built to last and I am not so sure on a cobra clutch. I went the c-4 route as c-6s make running the exhaust more difficult. I would re-enforce the torque boxes for sure as well as the subframe connectors and make sure they were welded in properly. I would go with long tubes and look into tweaking the rear suspension if you plan on launching it hard. Is it a 4V Cleveland?
The block I bought is a 72, XY block and the heads are 4V closed chambers. Im going with a C-4 as well ( I have a few C-6s laying around but Im not a big fan...) and I saw those headers from summit...my god $600 for headers that arent even ceramic coated...I already have headers and an oil pan too..trying to find a Strip Dominator intake now..Ill be taking pics here shortly...
