351 Mustang
1990 351
Old Jan 16, 2008 | 12:29 PM
kaik1969's Avatar
kaik1969
Default 1990 351
I know this is not a mustang question, but I have an 1990 f-250 with the stock 351w and auto transmission in it and the problem is that under mild acceleration it sputters until i get above 2500 RPMs. Also it shakes alot when i am at a stop light in Drive but if i put it in nuetral it ideals great with no shaking. Any ideas?
Old Jan 16, 2008 | 01:27 PM
farseek1's Avatar
farseek1
Default RE: 1990 351
Sounds like plug wires to me, they will do fine without a load,put the least load on
thenthey misfire. One wire could be hanging loose orout of timing order. Check at night,
have some one sit in the truck and go from Drive to neutral, if bad normally you will see the
little blue sparks jumping to ground.Cant see themif not dark under the hood, If so
replace the plugwires, if that doesn't do it. Next would be the coil.Good luck
Ray
Old Jan 23, 2008 | 02:47 PM
kaik1969's Avatar
kaik1969
I tried that and everything checks out. It only happens between 1000rpm and 2500rpm. I am thinking timming chain?
Old Jan 23, 2008 | 02:58 PM
WhiteWindsor's Avatar
WhiteWindsor
I've got a 93 f-250 with a 351. I was having issue's similar to your's actually i still am. Mine would do what yours doe's and the tranny would kick down at time's when i did not think it should. When it did this it would rumble. I drained what fluid i could out of the tranny pan and put in a new filter. That corrected the problem for a year and now it has started again. I'm sure mine is tranny related because the engine was replaced a few months ago with a reman with a 3 year unlimited mileage warranty. It came with new timing chain and everything else, i just had to re-use my manifold and oil pan.
Old Jan 23, 2008 | 03:07 PM
kaik1969's Avatar
kaik1969
Wow, o.k ,I will try that. Alot less work than timming chain. Thanks everyone.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
14gt_Track
Oct 1, 2015 02:47 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
