351 Mustang
Looking to Tap ya'll's 351 knowledge!!!
Old Feb 1, 2008 | 04:46 PM
hillbilly pony's Avatar
hillbilly pony
Default Looking to Tap ya'll's 351 knowledge!!!
Check out the pics and the write up about this car and let me know what you think about it.
1987 ford mustanf GT 5spd transmission, 2nd owner and have treated car like a baby, car is in perfect shape, many modds done to the car. Have well over $20,000 invested through the years owned. Has new 351w built few months ago so car doesent even have 5k miles, car has a vary high 13.5 compression ratio and runs on 110 octane fuel so deff not a daily driver. Car has been built to run mid to upper 10's in a 1/4.
List of modds:
-351w engin
-ross custom dome pistons
-trick flow R heads
-trick flow R upper intake
-trick flow R lower intake
-24lb injectors
-crane gold rokers
-75mm throttle body
-mass air converted
-cold air induction system
-msd ignition box
-electric fan
-hooker long tube headers
-king cobra clutch
-steeda short throw shifter
-3.73 gears
-4in extended cowl hood
-stalker front end
-auto meter gauges
-new black carpet
-BF Goodrich 325-50-15 grag radials
-Mickey Thompson skinny's
-Weld racing rims
[IMG]local://upfiles/76007/89AF446E9CDE4EDEA28F69E72214065F.jpg[/IMG]
[IMG]local://upfiles/76007/C7B2F5D3A9FB471781D41A80EB762F39.jpg[/IMG]
[IMG]local://upfiles/76007/DBA65979C8C247FAAB371EA900447F0D.jpg[/IMG]
Old Feb 1, 2008 | 07:41 PM
dudeboy's Avatar
dudeboy
Default RE: Looking to Tap ya'll's 351 knowledge!!!
ORIGINAL: hillbilly pony
1987 ford mustanf GT 5spd transmission, 2nd owner and have treated car like a baby,... car has a vary high 13.5 compression ratio and runs on 110
If this guy has treated a 13.5CR motor like a 'baby'
Then take a look at his kids before you buy this car.
24's are probably too small for that CR
No mention of cam...
Old Feb 2, 2008 | 01:42 AM
w8less's Avatar
w8less
List of modds:
-351w engin
-trick flow R heads
-24lb injectors
-crane gold rokers
-75mm throttle body
-mass air converted
-msd ignition box
-electric fan
-king cobra clutch
-3.73 gears
-stalker front end
-auto meter gauges
-new black carpet
-Weld racing rims
that car has been run hard if they set it up to be on race fuel
and 24s are too small
Old Feb 2, 2008 | 01:48 AM
AdderMk2's Avatar
AdderMk2
Banned
he probably meant 42
Old Feb 2, 2008 | 01:52 AM
w8less's Avatar
w8less
i hope
Old Feb 2, 2008 | 07:35 AM
hillbilly pony
WOW that much of an injector?
I asked about the cam and he said he would look for the cam card. THe sticker on the back says lunati. Could be anything.
I am a little confused about injectors. i thought the injector size was mostly based on how much air it pumped...ie S/C or nitrous. How does CR change the need for bigger injectors??
Old Feb 2, 2008 | 06:20 PM
bighungrymatt's Avatar
bighungrymatt
yeah I doubt he babied it...
jwog666
Dec 27, 2021 08:09 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
accarter
Sep 21, 2015 11:56 PM
stark777
Sep 21, 2015 12:46 PM
