351 Mustang
will this work?
Old Feb 16, 2008 | 09:29 PM
a89fiveoh's Avatar
a89fiveoh
Default will this work?
ok im in the process of selling my engine to this guy that has a 95 mustang gt. I have a 306 with 351 heads on it. It has a carb set up. The intake manifold that i have on it right now is a 302 manifold. i believe that it will work but he is not sure that his intake manifold will fit... yes or no
Old Feb 16, 2008 | 09:53 PM
HYPEracing's Avatar
HYPEracing
Default RE: will this work?
if you have a 302 based motor, and he has a 302 based intake, regardless of the heads, if they are windsor heads, his intake will fit. If you had a 351 block, a 302 intake would not fit, or if you have cleveland heads then it would not work. The only difference between 302 heads and 351W heads is the size of the head bolts, there 1/2" holes in the 351 instead of the 7/16" holes in the 302, every thing else is identical.
1TUFF302
Nov 5, 2015 04:02 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
