1996 351w Block
1996 351w Block
Whats the limits on a 1996 Windsor Block as far as how far can I push it without having the same failure problems that are prone to the 302 blocks. I have found one in a 1996 truck, and it's super cheap, $250 bucks and they pull it. Wanting to get into the deep 10's possible high 9's on engine only. Thanks
RE: 1996 351w Block
Woodsy, I sent you a PM, I don't know if you can receive them or not, if you didn't get it let me know and I will ask the questions again in here or over the phone or what ever it takes.
RE: 1996 351w Block
I was going to put one together with about 11.5-12.0 to 1 compression. Was going to get a set of AFR 205's or so with a custom cam for Jay Allen. Was wondering if I could stroke the late model block out to a 427cid or would it be a safer roll of the dice to leave it 408cid. Just looking for a minimum of 600 at the crank and everything after that will be just bonus HP.
RE: 1996 351w Block
If a man wants or just has to have one of the 427 windsor's, what do you recommend Woodsy? I will probly just stay with the 408, beings I have had so much trouble building this last car, I don't need any more surprise fugg up's. I don't know if I can safely handle much more crap outta this car I'm finishing up right now. I had to walk away from it yesterday so I wouldn't break something that wasn't allready tore up. But with persistance and the abiltity to controll myself much better than compared to when I was younger, I will manage to press on and finish my little beast.
