351 Mustang
EFI help
Old Sep 24, 2008 | 11:23 AM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
Default EFI help
alright, almost the entire motor is done, basically everything from the oil pan to the intake manifold is together (even added a TFS nitrous kit just in case ;-)
my question for you guys is this, the TFS R-series manifold im using has a 90mm TB opening. the biggest TB i can find for a 94/95 is a 75mm. i know that using that small of a TB will really hold the motor back.
is there any way to utilize a Fox TB (for instance an Acufab 90mm) on the 94/95 computer? i can have the adapter welded up myself so i can use the stock cables and such, but i know the IAC motor wont swap onto the Fox TB. also what about the TPS? thanks in advance guys.
Old Sep 24, 2008 | 01:25 PM
dudeboy's Avatar
dudeboy
The ecu won't care what year the TB was intended for.
If you can get everything to fit properly, then go for it.
(I don't know enought about the sn95 setup to offer any more advice than that though)
I would think there would be a commercially available 90mm for the sn95's though...
Old Sep 25, 2008 | 09:43 AM
sn95_331_GT_ yellow
anyone?
Old Sep 26, 2008 | 04:31 PM
S351R13's Avatar
S351R13
You use a fox throttle body. You have to cut the connectors off and make your own connectors. Any autoparts store will have wire connectors. No one that I know of makes on specifically for a 94-95.
Ipaman
Sep 22, 2015 07:01 AM
jaiidutch
Sep 14, 2015 10:29 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
RAGNAROK
Jun 21, 2003 06:49 PM
