some questions on my build plan
im really leaning towards the 351w based block...even if its pricer i think it will keep me happy longer.
For a daily driver, i was wondering how this Short block + head combo would work, better then my initial plan?
http://www.buydart.com/index.php?mai...products_id=40
http://cgi.ebay.com/ebaymotors/ALL-F...spagenameZWDVW
and what style cam would you suggest (i will still have p/b), what compression would i be looking at on that set up?
Would twisted wedge heads work better for this application...
im keeping my typhoon intake but will have it ported
I don't think I would go that route. If you have a good local builder thats what I would do. I have a 408 with a comp cams hydraulic roller, Victor Jr. heads, and a Super Victor intake. Some people would say my heads are not the best (AFR often recomended) but it runs 6.8 on motor in the 1/8 in a full weight 90GT with a converter built for nitrous. It runs way better on the gas. If you must buy the engine online I would go with adperformance or fordstrokers. Those guys have a lot invested on Mustang boards.
That Typhoon will choke a 408.
With the 408 or 418 (ive heard 418 arent any weaker then the 408, "free horsepower")
and a good set of Dart 185's or AFR 195's, a custom cam from fordstrokers, and an good efi and correct maf/injector set up, what kinda numbers would i be looking at?
I run the Super Victor with the injector hole machined in. http://www.edelbrock.com/automotive_...efi_ford.shtml
The 418 can have clearance issues but if someone reputable does it no problem. I thik Fordstrokers uses Jay Allen for the cams so he should be involved with the head choice. Jay builds Canfield heads and I am not that familier with them. But for an AFR head I'd say 205 or 225 and if I had that setup with a good NA converter 6.2 in the 1/8 on motor at abour 112 mph.
to clear up the typhoon is not like the rpm 2 it is like the rpm .
and as far as what cc said i agree fordstrokers or adperformance for a short or longblock
and if your talking about buying the whole motor online then do as what was said and give jim of fordstrokers a call and work out the short block and at the same time him and jay allen and you can decide and figure out the top end and have them set it up and be done with it , get it home drop your intake,dizzy and drop it in and fire it up.
as far as numbers i think most decent built 408's make 500 to the flywheel pretty easily with decent/good parts and pretty much how dep your wallet is is how fast you want to make it...
i also am turning my 351 w into a 408 and have made a few calls/emails to jim to see what we can work out.
thanks, all help appreciated,
just curious, what is the efi intake of choice if not the performer...
i do want to stick with efi as of now, although could probably be swayed.
Im planning on buying a short block and a custom cam, probably from ford strokers, i may let them do the heads while they are at it, depending on what time period i end up stretching this across
The Super Victor in my link is for EFI. You would need the edelbrock fuel rail and an elbow. Then mount your throttle body to the elbow. I run a 4 hole but you would have to change your computer system.here is a pic.
