351 Mustang
throttle body, injectors?
Old Jan 4, 2009 | 09:55 PM
blwn93gt's Avatar
blwn93gt
Arrow throttle body, injectors?
Its been a long time since i posted here. I am still working on my 408w project, some things came up and i had to put it on hold for a while. anyway, i am back at it and need to know what size throttle body and injectors i should get. its a supercharged 408 stroker incase you guys forgot. i have 42lb injectors and a 75mm throttle body from my 331 stroker but i am not sure if it will cut it on the 408w.
Old Jan 5, 2009 | 10:46 PM
Liquid_02's Avatar
Liquid_02
I have 42# and an 80mm TB on mine, so you should be alright. 42# is good to about 600+hp and depending on your setup, the 75 should be perfect for it, I just went to the 80 just to be sure I had enough flow
Old Jan 6, 2009 | 09:14 AM
cccharleston's Avatar
cccharleston
With the supercharger you will need more injector. The throttle body should be as big as the manifold will allow.
Old Jan 7, 2009 | 10:47 AM
w8less's Avatar
w8less
i would go with a bigger throttle body if its in the budget, dont you have a R box intake? is it the 90 or 75 opening?
Old Jan 9, 2009 | 08:36 PM
blwn93gt's Avatar
blwn93gt
It has the 90mm opening. Thanks for the advise guys.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
GLOCKer
Sep 28, 2015 07:36 AM
2poor4u2
Sep 26, 2015 11:08 AM
