rockers
If unsure, check it. Pull off a I and E spring and put on a checker spring and turn it over and press on the valve and see how much clearance you have. You should have about .120 I and .80 E to be safe.
Assuming your 351 is a roller? If not that cam won't work for you, you'd need one for flat tappet lifters
Also I wouldn't put that cam in your engine... DO NOT cheap out on the cam, the cam is the heart of the engine, changes all characteristics of it. Get a custom grind, they're only about $250
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
JDWalton
Sep 24, 2015 08:47 PM
