351 Mustang
Windsor SR heads
Old Apr 6, 2010 | 09:52 PM
Black89LX's Avatar
Black89LX
Default Windsor SR heads
so I am looking to get the bare heads from summit in the future, where can i get the valves? would these ford valves work or what height valve do I need? they are 5.140"
http://www.summitracing.com/parts/FMS-M-6507-A351/
also, what kind of compression can I expect with a stock bottom end? I have used the calculators and got 10.5:1... it seems a little high, considering the heads have the same combustion chamber volume as stock...
Old Apr 8, 2010 | 07:10 PM
uedlose's Avatar
uedlose
so why not get the valves from summit also???
Old Apr 8, 2010 | 09:37 PM
Black89LX's Avatar
Black89LX
I was planning on getting these valves, but I noticed that there were different size valves, like stem height. For example, trick flow valves have a 4.960 stem height, scorpion performance valves have a 5.260 stem height...
for those of you who have windsor sr heads, what length stem do your valves have?
does it really make a difference??
Old Apr 9, 2010 | 06:22 AM
uedlose's Avatar
uedlose
Yes, the valve stem length makes a difference. Call Dart see what they recommend. They probably are running a Stock length Chevy valve or maybe a +.100 so you can run a taller spring for more pressure and or no coil bind.
Old Apr 9, 2010 | 01:04 PM
Black89LX's Avatar
Black89LX
well they said stock length, whatever is stock for the motor.
anyone know what that might be?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
bradleyb
Nov 27, 2015 07:50 PM
kevsgt
Oct 9, 2015 10:12 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Drastang
Sep 30, 2015 03:48 AM
