351 Mustang
Holley Systemax
Old Jun 2, 2010 | 10:32 PM
89coupe's Avatar
89coupe
Default Holley Systemax
Have the intake on my 347. working on a 427 single turbo combination. its the systemax II efi intake. just wondering if you can make this intake work? probably not but just thought that since I have it I would try to make to it work if at all possible. thanks for your help
Old Jul 8, 2010 | 09:28 AM
DeathRattle's Avatar
DeathRattle
You'll need a new lower intake manifold because the 351 block is a different size/ I think it's wider and taller. The upper intake will bolt to the lower but I don't think the Holley Systemax will flow enough...If you're gonna do a 427 turbo then why not sell the Holley intake and use the money to get something like the Trick Flow Box-R or BBK SSI-R??
Old Jul 8, 2010 | 11:28 AM
ProTrickVic's Avatar
ProTrickVic
personally i suggest an EFI super vic for a 351 and a 90* elbow set up.
you're gonna need some big azz injectors on that set up.
Old Jul 8, 2010 | 04:39 PM
uedlose's Avatar
uedlose
I am with him ^^^^^. that holley could work you are forcing the through it BUT you would be way ahead of the game to run the carb style set up for EFI. do a search if you want to use the holley they make sapcers for this..
What size turbo you gone to go with?
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
LiquidDrink
Sep 29, 2015 10:06 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
Wombatnation
Sep 13, 2015 09:16 PM
WDScott
Aug 17, 2015 06:38 AM
