Fairly well built 351w puts down 255hp?! I NEED HELP!
I believe my gears are 3.08. The reason i went with 24 lb injectors was because the factory 19 lb ones are good up to 300 hp an the 24s are good to like 400. I'm trying to pick out a new cam. my heads don't flow so well on the exhaust side so i'm thinkin more duration.
those heads have good flow numbers for no more than what they cost..get a cam that has more exh duration and lift (most cams do anymore) and defiantely some bigger injectors..you don't want them maxed at thier limit..something in the mid 30's would be good and another thing is if you throw some 3.73's in your stang it will make a world of difference..oh yeah and 75mm throttle body..
yeah that chip came out the day I did the dyno lol. a friend of mine has some 30 lb injectors kicking around. Maybe i'll throw them in there soon along with a new cam. I really could use some help with selecting one. i have 1.7 rockers so i can't go too big with the lift, and my compression ratio is only 9:1 so i can't use too much duration.
The only thing wrong with it is the cam. Not nearly enough duration. Plus I had the stock 58 mm throttle body on it. I don't see whats wrong with iron heads and hypereutectic pistons. Not all of us can afford forged and domed pistons, h-beam rods, and a set of a AFR 225s
Dragonus18
09-09-2015 01:21 AM
