351 Mustang
flexplate and flywheel ?
Old Sep 9, 2010 | 08:47 PM
87Stallion's Avatar
87Stallion
Default flexplate and flywheel ?
What flexplate and flywheel do I need to bolt a roller 351W to a T5?
Can I reuse any of my 302 stuff? I know I cant use the flywheel due to the balance diff.
Old Sep 9, 2010 | 10:57 PM
Venomantidote95's Avatar
Venomantidote95
should get away with all but the flywheel!
Old Sep 10, 2010 | 02:33 PM
wildcobrar's Avatar
wildcobrar
351W is 28oz set up.
Joe
Old Sep 10, 2010 | 02:42 PM
87Stallion's Avatar
87Stallion
Yeah I knew that but I was wondering what vehicles with a 351W can I get thre flywheel from? Id imagine it would have to come from a stick shift truck as Im bolted a T5 to it.
Old Sep 10, 2010 | 07:22 PM
Randys66gt's Avatar
Randys66gt
Flexplate is for an automatic and a flywheel for a manual. This is what I run:
http://www.summitracing.com/parts/FIZ-186511/
Old Sep 10, 2010 | 10:59 PM
87Stallion's Avatar
87Stallion
I thought I needed a 157 tooth flywheel not a 164 tooth
Old Sep 10, 2010 | 11:05 PM
wildcobrar's Avatar
wildcobrar
You will not find a 157 tooth flywheel on any truck to fit your car. They were all 164 I believe and could run an 11" clutch. The one production car that comes to mind with a manual tranny and a 351W is the 95 Cobra R that was white and there were only 300 produced. That car had a 157 Tooth flywheel.
Ford Racing has a Billet 157 tooth Flywheel that has the bolt on weights 50 or 28 oz.
I have used it, nice piece. BTW I have called quite a few times just to help you out. I have had no luck reaching anyone.
Joe
Old Sep 10, 2010 | 11:09 PM
87Stallion's Avatar
87Stallion
So I can run a 157 tooth flywheel? I got your message. Ive been in the garage pulling the old tired 306 out and getting ready for the next one. I will give you a call tomorrow if you are around. Again I appreciate the help. Not alot of help on here unless you are running the same ol 347 every tom dick and harry is running these days.
Old Sep 12, 2010 | 12:23 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Yes you can run a 157 tooth flywheel. Also since it sounds like you didn't know the difference between flywheel and flexplate be sure to get the right bolts that bolt it to the crank. Flywheel to crank bolts are longer than flexplate to crank bolts....
Old Sep 12, 2010 | 12:55 PM
87Stallion's Avatar
87Stallion
Yeah I was half asleep when i wrote this. I meant "block plate" not flex plate.
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
