351 Mustang
C4 in a 94-95? anyone do it?
Old 04-13-2011, 09:08 AM
Dwoody85
Dwoody85's Avatar
Default C4 in a 94-95? anyone do it?
I may have a bead on a new C4 for little cost and just wondered if anyone has installed one in that body style? Bolting to 351w
Custom fab a cross member or do they sell aftermarket?
Dwoody85 is offline
Old 04-13-2011, 09:13 AM
Dwoody85
Dwoody85's Avatar
Ha, just answered my own question. AJE racing has one for $160.
Will I have to mangle the interior to get the shifter positioned correctly?
Dwoody85 is offline
Old 04-13-2011, 08:50 PM
87Stallion
87Stallion's Avatar
Well this may not help you but I just put a C4 in my fox and I got the shifter to fit in the factory location. I cant see it being much different with a 94-95
87Stallion is offline
Old 04-14-2011, 11:38 AM
AdderMk2
Banned
AdderMk2's Avatar
id prefer to run a AOD with a manual valve body... but if you want to give up your OD... go for it.
AdderMk2 is offline
Old 04-16-2011, 08:48 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You should be able to use your stock crossmember. I'm not completely positive about the 94/95 but the fox crossmember can be adjusted if you grind away the welds that hold the bushing casings onto the cross member itself. Then they can slide back and forth. It will fit just fine. As for a shifter you should be able to use your stock one if you can get your cable to hook up right. They have a 1,2,d pattern so they both have 3 drive positions and the normal N,R and P.
I would get the AOD built though to keep the OD like Adder said but if you find one for the right price then go for it.
projectresto83 is offline
Old 04-18-2011, 11:22 AM
Dwoody85
Dwoody85's Avatar
Sorry it took me a while to respond been having some medical issues and been in and out of the hospital.... =( great way to start summer.
Anyway I found a '79 C4 out of a 4 cyl car for $50..... Did ford change the internals depending on application back then or were all C4's the same given they were made around the same time? The guy had it setting for years in his garage and figured hed just get rid of it.
So now Im possed with keeping my 4r70w which is already installed and just change the valve body to full manual, or get this C4 and more then likely have to modify drive shaft, and possibly rebuild it. I really dont mind the full manual.... I rarely get to drive the car anyway and just putting it in drive and going is getting boring, lol. Not to mention I have to keep messing with the TCS unit to keep it calibrated right.
Any suggestions ? Do the 4r70w trans made in '98 on differ from V6 to V8 model mustangs?
Dwoody85 is offline
Old 04-18-2011, 11:35 AM
AdderMk2
Banned
AdderMk2's Avatar
the v8 model 4R70w will not bolt to a 5.0... where the 3.8l will
AdderMk2 is offline
Old 05-08-2011, 01:40 PM
Venomantidote95
Venomantidote95's Avatar
If you do overhaul your aode then checkout www.becontrols.com for the better options in increasing your transmission power handling capabilities! I found them after the fact but next time im for sure using them for parts!
oops wrong thread but anyway its here now!
Venomantidote95 is offline
Old 05-10-2011, 07:17 AM
Dwoody85
Dwoody85's Avatar
lol I already am using their TCS unit, works for what it is. I just prefer to go to a manual valve body now. Worked fine though. After I put this C4 in I will be selling the unit.
Dwoody85 is offline
sprayed347GT
05-24-2004 03:01 AM
sprayed347GT
05-24-2004 12:28 AM
customper4mance
01-13-2004 01:32 AM
Strike
10-12-2003 06:39 PM
jhogan2424
09-02-2003 12:04 PM
Quick Reply: C4 in a 94-95? anyone do it?
