tlock
Old Jul 24, 2006 | 05:27 PM
petepete's Avatar
petepete
Default tlock
I already have one and installed but just saw this on v6 mistang stuff Most V6 Mustangs with the 7.5 inch rear end never came stock with a T-lok (limited slip differential) which allows both wheels to have power to the ground. Usually only one wheel, the right-rear wheel has the power. Upgrading to a T-lok is one of the best modifications you could ever do.
It says most did not come with one. What does that mean? was there a certain build date they stopped putting it in? could help someone trying to get one
Old Jul 24, 2006 | 06:26 PM
FastLane034's Avatar
FastLane034
Default RE: tlock
From what I know, I dont think any sixers came with a tlok. I know I will be getting one soon.
Old Jul 24, 2006 | 06:31 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: tlock
No V6 comes with an LSD. It's a good upgrade, I would definitely get one.
Old Jul 24, 2006 | 06:42 PM
bztz4m's Avatar
bztz4m
Default RE: tlock
When you update gears and add T-LOK are these two separate parts or do the gears if you order T-LOK come together as one part? And how many more RPM's do you turn if you upgrade to a 3:73 rear end gear.
Old Jul 24, 2006 | 06:52 PM
BlueStang6's Avatar
BlueStang6
Default RE: tlock
ORIGINAL: bztz4m
The ring and pinion gears are ordered separately from the LSD. T-loc is a spring/clutch type Limited Slip Differential and you also might want to look into a Detroit TrueTrac which is a gear type LSD. As for the RPM's; at what speed are you talking about?
Old Jul 24, 2006 | 08:02 PM
bztz4m's Avatar
bztz4m
Default RE: tlock
I looking for an overall RPM increase at driving in the city and hwy at 65 mph.
pat6674u's Avatar
pat6674u
Default RE: tlock
3.73 gears you average about 300-500 more Rpms. 1st gear will pull to 20 mph instead of 25 mph, 2nd goes to 30-35 mph instead of 40 mph. Top end cruising at 80 mph you are turning right under 3000 rpms.
Old Jul 24, 2006 | 10:07 PM
bztz4m's Avatar
bztz4m
Default RE: tlock
Thanks again for the info.
Old Jul 25, 2006 | 01:58 AM
orion6g's Avatar
orion6g
Default RE: tlock
ORIGINAL: pat6674u
Do you have the manual or the auto?
would you happpen to know what speed you go at 5,000rpm in 5th with 3.73's?
Old Jul 25, 2006 | 11:43 AM
pat6674u's Avatar
pat6674u
Default RE: tlock
I actually should revise my numbers a bit. Yesterday I took a good look at my rpms and on the freeway at 90 mph I was turning 3000 rpms. There is no reason for me to find out how fast I'm going at 5000 rpms in 5th gear. I was surprised the freeway was clear enough yesterday to let me go 90. Also, we make most of our power in this car between 2500-4000 RPMs. Given that, here are the shift points I came up with in my manual V6
1st gear 20-25 MPH
2nd gear 40
3rd gear 60
4th gear around 80
5th cruisin'
I'm no mechanic but that is just regular driving on my car. I could probablt push all those gears more but its probably not worth it.
Shaunmac9128
May 14, 2009 02:55 PM
SidewayzStang2
Dec 8, 2008 09:28 AM
BWfVA
Aug 28, 2008 02:05 PM
BWfVA
Jan 1, 2008 09:37 PM
Deepenough
Nov 27, 2007 11:31 AM
