bad fuel pump?
Old Mar 9, 2007 | 12:48 PM
DelStang86's Avatar
DelStang86
Default bad fuel pump?
The past few days (although it has been about 20 deg. f), I've had trouble with my car stalling and or not starting... the starter is definitely functioning, and there's no problem with the electronics, but if i start the car, it flutters and then stalls. what do you think the problem might be? I'm not really able to take it to the dealer right now, 1)because i don't have the cash/ nor would i want to spend it getting an obd2 scan run on the car (which is mandatory...), and 2) I have to work this weekend. The car is under warranty and is just shy of hitting 15k miles.
Old Mar 9, 2007 | 01:01 PM
A_Sixer's Avatar
A_Sixer
Default RE: bad fuel pump?
It is under warranty....Take it in....It should not cost you a penny!!
Old Mar 9, 2007 | 01:02 PM
wolfey2k's Avatar
wolfey2k
You may have ice buildup in the fuel system or you could have a faulty fuel pump or perhaps the fuel filter is clogged.
You shouldn't have to worry about paying for anything as the vehicle is still under warranty.
Factory covers all expenses and if your shop is charging you a penny for any work, they are ripping you off! Your coverage is bumper to bumper. They have no business charging you anything.
Ask them if they have a loaner car you can use while your's is in the shop. Most dealers do but people usually don't know that as some dealers don't promote it. Ask.
Good luck!
Old Mar 9, 2007 | 01:38 PM
SOHCman's Avatar
SOHCman
ORIGINAL: DelStang86
If you have an 05/06 check out my older post. I think the 07s have the newer pump.
https://mustangforums.com/m_2789752/tm.htm
Does any of these also apply?
As wolfey2k states, a bad pump or filter, the TSB covers it. No charge.
SOHC
1TUFF302
Nov 5, 2015 04:02 PM
9550
Oct 26, 2015 05:01 PM
tramphardrocker
Sep 13, 2015 08:56 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
