Ford racing tlok
Ford racing tlok
is it true that the ford racing tlock is junk cuz i dont want to spend 500 on a detriot but at the same time dont want to waste 200 on a piece of junk any info would be most appreciated thanks and have a great weekend
Dan
Dan
RE: Ford racing tlok
it depends on your use...if you are running a highly modified or f/i 4.0 and drag racing, the t-lok may not hold up over time. the detroit is definitely tougher, can take a lot of abuse. but if you are a daily driver who just likes to get on it and not a trackster, i think you'll be fine with the t-lok. JMO
from what i've read, the t-lok is plenty fine for occasional track runs and moderate modded stangs. if you're going big on mods and track runs, it would be common sense to buy the most durable parts. if money is an issue, then going big shouldn't be an option.
i blew my stock open up on stock 3.8 auto power ([&:]or whats there)if you dont keep hammering it im sure it will be fine, but if your into barking the tires, powershifting, chirping gears etc and drive your car like you should, just get a detroit, girdle, and panhard bar reloctaion, because when it comes down to it, the tlok MIGHT hold, the detroit you know WILL,
and for those that say just get an 8.8, well ive blown them up on a stock mach 1 so you mise well just build the 7.5
ORIGINAL: mustangman02232
squishbang
Suspension
11-02-2015 03:42 PM
