Axle code/gear ratio?
Old Mar 17, 2008 | 02:47 PM
Mercury83's Avatar
Mercury83
Default Axle code/gear ratio?
hey guys, what is the stock axle code/gear ratio for an 07 v6 coupe? thanks. also, i found the calibration code once before, but my memory needs refreshing as to where exactly it is!
Old Mar 17, 2008 | 02:50 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Axle code/gear ratio?
http://www.fordvehicles.com/assets/p...tang_specs.pdf
3.31
Its on the rear end
The calibration code is on front of the PCM
under the hood by the BEC or fuse box.
[align=left][/align][align=left][IMG]local://upfiles/69445/898861EEF78E47D787706C8E1DC8D025.jpg[/IMG] [/align]
Old Mar 17, 2008 | 11:23 PM
elroyjetson_1978's Avatar
elroyjetson_1978
calibration code is the 4digit code on the side of the pcm under the hood to the passenger side torwards the front.
axle ratio is 3.31:1 and the code is on a sticker on the axlecover with the ratio
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
Sep 24, 2015 09:18 PM
Sep 3, 2015 07:14 PM
