transmission swap?
transmission swap?
What would it take todo a transmissionswap for aGT takeoff trans??? I am just curious really, may consider doing it but haven't decided yet.
Any ideas or help would be greatly appreciated......
RE: transmission swap?
You need to talk to this guy
http://4.0collective.com/showthread....ghlight=tr6060
check this link out for the adaptor plate you will need
ORIGINAL: Mustangs4U
No, I have the stock T-5 manual transmission that the 4.0 comes with and was just wondering what it would take to replace it with the t-3650 manual transmission from the GT.
unless youre gonna be puhsing some high numbers the t-5 will be fine... and then you should put in something a bit beefier than the t3650... but if you insist haha... youll need an adapter plate and will you need that pinon flange for the d/s or not?... i think if you go to an aluminum d/s while youre at it you wont nee the plate... i may be wrong tho... someone else will be better suited to answer that
Sell the V6 and buy a GT that has the tranny you want.
Otherwise you will have a bastard stang that no dealership will touch.
More work than its worth, but to each his own.
Some people have more time than$$$ and some have more$$$ than time.
Then there are those that have both lots of time and money but dont know
what to do with it so they ask others.
Matt's 95 Stang
10-05-2015 07:16 AM
