gearing?
Old Nov 3, 2008 | 12:27 AM
D_hof_07_V6's Avatar
D_hof_07_V6
Default gearing?
its an 07 with BBk CAI and Single Flowmaster. what gearing should i get? 3.73 or 4.10? is there much difference in mpg loss between the 2?
Old Nov 3, 2008 | 06:39 AM
Daemos's Avatar
Daemos
From what I've heard, I'd go with the 3.73s.
Old Nov 3, 2008 | 03:09 PM
mustangman02232's Avatar
mustangman02232
3.73s will loose 1 mpg on the highway, 4.10s will loose you 2 mpg on the highway, city milage will stay about the same
you mise well get a detroit true trac LSD or an eaton, or swap an 8.8 in with those gears.
Old Nov 3, 2008 | 03:15 PM
28HopUp's Avatar
28HopUp
MF Administrator
It depends on your plans for the car. Naturally aspirated or forced induction? Daily driver or occasional track car?
If the OP is just wanting more grunt for a daily driver, then he could install a Ford T-Lok at the same time as the gears instead of the more expensive LSD's you mentioned. But if he plans to hit the track at all, then your advice is spot-on...
Old Nov 3, 2008 | 05:45 PM
basketballord's Avatar
basketballord
Agree to the above
and a common saying is "Don't Fear the Gear." If you plan on staying N/A, go with the 4.10s. If it's too much, you can always compensate a little with a taller tire. But I think you'll like the results.
Old Nov 18, 2008 | 08:23 PM
mustangman02232
Originally Posted by basketballord
Agree to the above
just go with 5.12s and a full spool
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
