Performance Suggestions
Old Feb 26, 2009 | 08:49 AM
  #31
jimkaray's Avatar
jimkaray
Drive Train Specialists have a wide variety of gears and brands. The first 3.73 they list looks to be a Ford brand gear. Based on the part # I assume it is new old stock and predates the creation of FRPP brand. Not all the listings indicate the manufacturer, MG in the part # must be for Motive gear. I'msure they can tell you if you ask. FYI: I see a set of used 4.10's for $100 in the Used Parts section.
Old Feb 26, 2009 | 09:59 AM
  #32
28HopUp's Avatar
28HopUp
MF Administrator
Originally Posted by tx_zstang
FRPPs are not available in 373's anymore for 7.5"? Wow.
Only thing I'd STRONGLY RECOMMEND is to really think through with what your plans are for the far in the future. If you plan to put a turbo or supercharger on some day, take the time and do the rear end right the first time. If you put a trac-loc in and gears and later put in a turbo or supercharger, you may be changing the rear end components again. The trac-loc on the 7.5" (v6s) is not very strong.But if you go with an eaton true-trac instead of a Ford trac-loc, you'll be good to go, regardless of what you do!
So if you can swing the extra 200-250 for the Eaton, do it!
Also, relating to the gear choice, if you ever plan to go turbo or supercharger, just do 3.73s now and not 4.10s. You'll go through 1st gear too quick with 4.10s with turbo or supercharger!
That's good advice. I will again add that my Natureally Aspirated 4.0L blew out the 7.5" 4.10's/t-lok from racing at the track. If you plan to race your car, then do the rear right the first time - either install the Eaton or go with the 8.8" GT take-off.
Old Feb 26, 2009 | 07:35 PM
  #33
wetwille3's Avatar
wetwille3
I will probley not turbo or superchrger it and a rarley go to the track. So the ford t loc is prob what i should buy.
Old Feb 26, 2009 | 08:40 PM
  #34
wetwille3's Avatar
wetwille3
Also, do i need to buy buy the pinion or does it always come with the grear?
Old Feb 26, 2009 | 09:05 PM
  #35
wetwille3's Avatar
wetwille3
Talking
I know i have so many questions. But when you say the ford racing t loc is not very strong. what do you exactly mean? Does it blow if i floor a few times? After re reading im not sure if i should go with eaton or ford racing
Old Feb 26, 2009 | 09:17 PM
  #36
jimkaray's Avatar
jimkaray
The gears always come as a ring and pinion set.
7.5 is plenty strong for your needs. Its just that they aren't up to the task if you will be beating on them regularly, or will be significantly boosting the power in the future with a power adder.
Old Feb 28, 2009 | 11:26 AM
  #37
BWfVA's Avatar
BWfVA
Well the motives dont whine if installed right I can tell you that from experience now. The 3.73 dont atleeast. Plus they will give you plenty of kick in the rear. As for your purposes I would say your fine. I have the tlock and it is holding fine
Old Feb 28, 2009 | 12:54 PM
  #38
wetwille3's Avatar
wetwille3
ok im gong with motives and the ford lsd
Old Mar 10, 2009 | 09:14 PM
  #39
wetwille3's Avatar
wetwille3
one more thing will i have to change my tune at all?
Old Mar 12, 2009 | 02:06 AM
  #40
my first mustang's Avatar
my first mustang
The Xcal will allow you to set your speedo for the new rear gear ratio. That's one of the parameters you can adjust with the tuner. When you first plug in it will ask you if you want to change any parameters, push yes and scroll down to rear gear ratio. What ratio are you finally getting? You will really love what gears & T-lok will do for your V6 Mustang.
