Temp gauge not moving from cold...
Mine was a bad gauge. You would get an engine under temperature code if the coolant
was too cold when driving. Also, if it blows heat, then it's not the T-stat. You can buy
gauge replacement kits on eBay. You can buy a cluster, then you devalue the car if you
do not get the mileage put into the replacement, but it would be a good time to upgrade
to the 6-gauge cluster, with the readout. You need the three button module too, but people
are selling them cheap enough on eBay. Might be able to get a MyColor cluster too...
THANK YOU!!! I’m so happy you replied. You are the only one who has ever posted the same exact problem and you hadn’t been on here in so long, I thought this was a long shot. I searched and searched. This really threw my engine shop since my wires once had a break and were reconnected multiple times. I will replace the cluster. Thank you so much for replying to me. 😁😘
Originally Posted by Hotgirl
I know this is super old, but what was the problem? I have the same EXACT issue and no one can figure it out. Gauge stuck on cold. Kill the engine and restart and it’s risen. I really hope you’ll reply. You are the only person on the Internet I can find who’s had this same exact issue.
try asking on www.MustangEvolution.com &/or www.TheMustangSource.com
those are pretty active;
search Google for other forums & try searching/asking in them
StriderTacticaL
14
Sep 10, 2008 05:52 PM
