Rev stopper
Rev stopper
I am not quite sure what to call it, but when I would sit there in nutrual and rev my engine to test my cool air intake it stops at about 4000 RPMS. Why is that?? Is there a way to get rid of it????
Its not a good idea to high rev any engine without a load on it. But it can be turned off with a tuner. The in gear rev limit is set just about 6000 or 6100 rpm. That's so you don't over rev the engine if you miss a shift or shift to late with an automatic. Also adjusted or turned off with a tuner. You should get a tuner and a GT takeoff muffler to get the maximum benefit of the cai. You will love the difference!
Its not a good idea to high rev any engine without a load on it. But it can be turned off with a tuner. The in gear rev limit is set just about 6000 or 6100 rpm. That's so you don't over rev the engine if you miss a shift or shift to late with an automatic. Also adjusted or turned off with a tuner. You should get a tuner and a GT takeoff muffler to get the maximum benefit of the cai. You will love the difference it's make on the Mustang V6!
Offendant
09-23-2015 07:21 PM
