P0605 Trouble Code - Accidentally started engine during stock tune load
Old Jan 10, 2010 | 03:52 PM
kaihila's Avatar
kaihila
Unhappy P0605 Trouble Code - Accidentally started engine during stock tune load
I'm getting P0605/P1000 Trouble Codes after I loaded the stock tune. I made the mistake of turning the engine on during the load of the tune. Somehow, I read "engine" rather than "ignition". (I don't know how I did that...) Did I damage the PCM? Is there anyway I can repair this without having to purchase a new one? Would my car still be running perfectly if the PCM was damaged? Thank you!
Old Jan 10, 2010 | 06:26 PM
JimC's Avatar
Super Moderator
Here is what the codes mean:
P1000 OBD-II Monitor Testing Incomplete
P0605 Internal Control Module Read Only Memory (ROM) Error
Have you tried to simply reload the tune properly?
Old Jan 10, 2010 | 06:54 PM
kaihila's Avatar
kaihila
I have reloaded the tune and also reset the battery. Check engine light came back on. Car is running great though...
Old Jan 11, 2010 | 02:51 PM
vbrecken's Avatar
vbrecken
Don't know which tuner you have but with the SCT tuner there is an option to clear the code. Not all codes clear with a restart or a battery disconnect.
Old Jan 11, 2010 | 04:27 PM
kaihila's Avatar
kaihila
I have a DiabloSport. I called them this morning and I was able to clear everything up. So far, no check engine light! I did no damage to the PCM. I guess the stealership will not be getting my money for a new one. :P
Old Jan 11, 2010 | 05:31 PM
Nuke's Avatar
Nuke
It's easy to go into panic mode when that stuff happens. Sounds like you tried to keep your cool and called the manufacturer and got it straightened out. I figured it was just a matter of clearing the codes and starting over.
Old Jan 11, 2010 | 06:27 PM
killdar's Avatar
killdar
my guess is you had to use the clear codes func on the diablo
Old Jan 12, 2010 | 12:05 AM
kaihila's Avatar
kaihila
The first thing I did was clear the codes yet they returned after I had started the car a second, third, fourth..etc. time. That's when I knew something was wrong but it's fixed now!
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
msavoia23
12
Jul 7, 2018 12:08 PM
Jacob4589
Aug 17, 2015 09:34 PM
'stangdude
Aug 12, 2015 01:27 PM
