Help installing aftermarket stereo, NO ACC WIRE?
So i went to best buy and bought a new sony headunit, a wiring harness and a dash kit.. i've installed plenty of stereos before but this mustang is confusing.
It's a 2009 v6 base with standard audio.
I cannot locate a working ACC/ignition wire.
The constant power works, and if i merge the constant and the acc together the deck works but will not turn off (obviously since its CONSTANT)
so how in the world do i hook up an accessory/ignition wire to trigger the headunit?
Thanks,
Thanks,
Thanks,
Thanks,
