Manual transmission fluid for t-5
When I had a T5 I ran Amsoil 5W30 100% Synthetic Manual Synchromesh Transmission Fluid in it instead of ATF and it worked much better than ATF. I now run the same stuff in my TR6060 and it shifts as good as new and has over 100,000 miles on it. You will need 3 quarts but the transmission will not quite take all three before the fill line is reached, which is level with the bottom of the fill hole on the T5.
BeatnikFink
10-01-2015 08:00 PM
09-25-2015 06:42 PM
